Edelbrock base & Runners HELP!
Old Oct 6, 2006 | 10:59 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Well here's the scenario, 92 trans am 5.7l. I bought the Edelbrock tpi intake and runners. Went to put them on today and found out the rear injectors hit the runners. So they don't fully seat into the intake. Needeless to say I was upset. I called Edelbrock they say I have the wrong intake. Bought the runneres and intake are sold as a complete setup. They keep trying to tell me it's because I have stock heads. I don't know what that has to do with the fuel rail and injectors. The intake fits just fine on the block, everything lines up. So I think I'm just going to send these back to summit. Has anyone else had these types of fittment problems? I need a good set up that will bolt up without any major altering. Any ideas? Thanks for the help.
Old Oct 11, 2006 | 10:12 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Transmission: 4 spd auto
Contact the Summit techs. Stupid question do you have the runners on the correct sides? The Edelbrock tech I talked to wasn't very knowledgable. That setup is supposed to be C.A.R.B legal, 50 state emission. That is defined as a a direct factory stock replacement here in CA. Wouldn't be if the heads had to change. I just put the manifold on with AS&M runners and had no issues other than the injector rail didn't align too well with the mounting bosses. Not much though and a little file work fixed it. The injectors still have to meet the intake runners at the stock location. I'm in agreement with you on the heads. No bearing on it at all.
Old Oct 11, 2006 | 10:47 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
i was going to ask the same thing, they go different angles, but im not sure if the bolt holes line up on the opposite sides, see if your plenum fits correctly, that would be a dead give away.
Old Oct 12, 2006 | 09:21 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
the accel runners that i have say in the instructions that there is a chance the injectors will hit that you may have to grind some material away from the runner area.
88SS6SPEED
Nov 11, 2015 07:05 AM
Chas91Z28
Oct 22, 2015 10:12 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
toronto formula
Sep 10, 2015 07:31 AM
