damper differences
Old Oct 9, 2006 | 09:38 PM
RArnold's Avatar
Car: 1984 Camaro conv
Engine: 350, .040, warmed up
damper differences
besides diameter, how different are vib dampers between a 350 s 305 sbc? are they interchangeable???
Old Oct 9, 2006 | 09:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
they're all internal balanced motors so they will interchange, although they're around $40-65 from summit for new non-SFI approved ones.
Old Oct 9, 2006 | 09:51 PM
RArnold's Avatar
whats SFI...?
Old Oct 9, 2006 | 11:01 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
An SFI aprroval means that particular component is built to spec's required for a particular racing sanction.
Old Oct 10, 2006 | 12:04 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The 350 one is 8", and heavier, meant to balance the harmonics of a heavier rotating mass. The 305 one is 6 3/4", meant to... well do the opposite.
You can use either one, the lighter one tends to make the motor rev easier (apparently), but the 8" one... Makes it more smooth? I forget offhand...
If you're not bracket racing, or constantly above 6000RPM, you don't need the $250 SFI approved one, you can use the basic $60 summit (or local) style one.
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
