oil pump help. please read
Old Oct 12, 2006 | 10:05 PM
355gta's Avatar
Car: 1989 pontiac firebird trans am gta
Engine: 355
Axle/Gears: 327:1 9 bolt
I have got the new motor in my car and when we fired it fir the first time it had no oil pressure, but the lifters did not colapse. We hooked a drill to the primer and spun it and nothing. we then spun the drill backwards for a while then went forward againand it puked a little out of the boss in the back of the block then nothing. It will do this everytime. has anyone come across this, and if so, how do i fix it.
Old Oct 12, 2006 | 10:20 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I tired priming both my motors but never got anything. I just fire it up and there she went. Did you hook up a mechanical guage when you started the car the first time?>
You should have pipe plugs in the rear 3 bosses. Oil should be comin gout of those unnless you left them out.
Old Oct 12, 2006 | 10:26 PM
355gta's Avatar
Engine: 355
No pressure at idle on the mechanical gauge. I let it idle for 15 min. and nothing, but it did not hurt the motor I dont think. 0 oil pressure for 15 min. should have casued some kind of knock or colapsed lifter.
Old Oct 12, 2006 | 11:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You're sure your gauge works?
Old Oct 12, 2006 | 11:20 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
After 15 minutes did you have oil coming up through the pushrods? If so you have oil pressure.
Old Oct 13, 2006 | 03:00 AM
355gta's Avatar
Engine: 355
nothing, i am just not convinced the pump is bad. think there is another problem.
Old Oct 13, 2006 | 03:17 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Your suppose to pack the pump with vasoline when you install it to make it prime right the first time. With it you have 100% success every time, without, its 50/50 it will prime right before hand.
Don't use anything but it though, never grease.
Old Oct 13, 2006 | 03:24 AM
ede's Avatar
ede
a SBC oil pump will prime it's self when you put oil in the engine, some other engines need the oil pump filled to help the prime. if the engine ran for 15 minutes you don't have zero oil pressure.
Old Oct 13, 2006 | 08:04 AM
Vader's Avatar
But what about TMT, Slick50, and ProLong? Everyone knows if you've ever used those, you don't need to use oil in the sump. I even saw it on TV, and I'm sure it was clearly demonstrated in their FTC fraud hearings...
Where are you checking pressure?
Old Oct 13, 2006 | 09:14 AM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
Is the oil pickup tube and screen damaged, loose, or missing? Are you sure you put oil in it, how much? 15 minutes with no pressure is BAD. I suspect that your bearings and cam have significant wear, especially if they were new and tight.
Old Oct 13, 2006 | 01:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I saw this once, helping a friend fire up his engine for the first time. Did the drill on the oil pump drive and couldn't get any pressure. Then found we were standing in 5 quarts of oil. No oil filter was installed.
When you had the drill on the pump drive, was there a decent amount of torque required to spin the pump? There should have been. You can feel it once pressure starts to build. Also the drill will slow down (unless using one of the 1/2" 2 HP models).
There are several areas that are common to lose oil pressure. The 3 plugs behind the cam timing gear may be missing. The pump regulator may be stuck open, or the retaining pin broke and the regulator piston is in the pan.
RBob.
eightsixseven
Dec 16, 2024 01:50 PM
toronto formula
Nov 10, 2015 06:17 AM
backtothe80s
Sep 5, 2015 12:39 AM
beachrodder
Aug 25, 2015 08:05 AM
Navy8125
Aug 21, 2015 09:32 AM
