27* WTF???? Need help quickly
Old Oct 17, 2006 | 03:07 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I timed my motor it was at 27* factory is like 8*?
So I put it at 8* now the car runs like crap!!!!! wont rev past 3500 or 4000 now Was my cam installed wrong? Is the ECM messing me up? WTF!!!
Old Oct 17, 2006 | 03:12 PM
Sounds like it was timed more or less correctly before; and you messed it up by setting it to the "spec" without disconnecting the EST wire.
Old Oct 17, 2006 | 04:30 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Yeah I disconnected the wrong connector I found that out a while ago. Sorry... let the thread die lol
Old Oct 17, 2006 | 07:31 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
But he posted like 5 min after you created this thread, which was today
Old Oct 17, 2006 | 07:48 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
yeah yeah , I left as soon as I posted and retimed the motor and came back... never saw the reply
Old Oct 17, 2006 | 07:59 PM
Guest
Guest
Posts: n/a
I know you solved your issue, but I made the mistake of setting my timing once after a balancer had slipped, boy did it run bad. Took me a little bit to figure out that one.
Old Oct 17, 2006 | 11:51 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i hear ya on that one. same thing happened to me but, the timing was way off, literally 90* off .
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
