"theory" and "real world"
Old Oct 17, 2006 | 04:53 PM
SnoFalls's Avatar
I'm going to ask this here cause the various board lurking I've done makes me think someone here will know ...
In reading this (a very good read BTW) ... I saw ...
"Then there are temperature variations due to the changing pressures and absorption from hot engine parts. These variations cause changes in the local sonic velocity."
I understand that different pressure and/or temperature can effect the sonic velocity, but IMO only until the engine has "warmed up" ...
At that point, wouldn't the sonic velocity become nearly constant? e.g. Isn't this an "equation of state" situation?
Or is the point that the temperature (aka pressure) is variable due to differing RPM's, So, there is no "constant" temperature ...
I know this is beyond "general tech", but lurking has shown some folks that have both "theory" and "real world" experience that might help me understand ...
Old Oct 17, 2006 | 05:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
interesting article.
If you enjoyed that, you'd also like to read the David Vizard book on porting small block chevy cylinder heads. Same stuff, but a bit more applicable to the SBC (rather than formula racing heads).
Your questions seem more like something a prof of mine would ask, so i'm holding out for a paycheck, or a grade, before I cough up my info
This picture I found was the best to illustrate what is what, as far as porting goes.
Old Oct 17, 2006 | 06:38 PM
SnoFalls's Avatar
ya never know ... the Q might show up on a test
and yes, this pic does 'splain stuff ...
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
