every step i take to fix my idle, it makes it worse
Old Oct 21, 2006 | 05:34 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
first off its a 91 305 tbi, 5peed swap
i have a very high idle when my car starts at anypoint, its worse when its cold, but thats because its still in closed loop. when its cold it idles at about 2000-2100 RPMS until it warms up and then it drops down to about 1400-1700 depending on what mood its in... and i cant for hte life of me figure out what the problem is
ive checked and cleaned my IAC, as well as set the idle a FEW times... it will set the idle fine with the pins A&B jumped on the ALDL, turn it off plug everything back in the right way and start it up... runs fine, take it for a ride around the block, bring it back and shut it off.... start it up a few minutes later and the problem is back. and the thottle linkage stop is not touching the idle set screw stop on the TB itself... even though the IAC is cleaned, could it still be bad, anyway to test if it is bad or not ?
i checked the TPS, seems to be normal
sprayed down the engine back with carb cleaner to look for any vacum leaks and coudlnt find anything at all
the only other thing that i can think of would be my timing....
the car used to be a auto... now its swapped to a manual, should i have reset my timing when i swapped it over ? is the computer still looking for the torque converter and causing the engine to idle high because its not there to slow it down ?
Old Oct 22, 2006 | 09:13 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
We just had a chevy suburban at work (305 TBI) that did the same thing. Mechanic at work tried everything until he gave up and sent it to the shop. It WAS a vacuum leak. I'll try to find out where it was tomorrow.
Old Oct 22, 2006 | 10:20 AM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
If the throttle linkage stop isn't touching the screw at closed throttle, then your throttle is sticking open. If your problem was a vacuum leak, you would not be able to set the minimum idle RPM at all. It just would not go any lower.
Old Oct 22, 2006 | 10:52 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Good point. Did you try manually closing the throttle to see if you ccan get the stop to touch? It could also be that somebody backed off the idle screw to the point where it can't touch.
Old Oct 22, 2006 | 01:33 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I assume you changed ecm's, right?
Old Oct 22, 2006 | 04:34 PM
Car: 91 formula
Transmission: t5
it isnt touching when the car is running... but when it is off it does
i can push it back to the screw... but it just goes back to where it was after i let go
no, and that was my first though but i have talked to a few people who have done this swap and not changed ECMs and not had any problems....
I tried a new IAC valve today and that didnt work, so now im thinking it is vacum, even tho i went through a whole can of carb cleaner in the engine bay looking for a vacum leak
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Sep 17, 2020 08:26 AM
mustangman65_79
Apr 14, 2017 05:37 PM
86IROC112
Aug 17, 2015 02:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
