How to Remove Coolant Tank under hood??
Old Oct 26, 2006 | 02:50 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
How do I remove the engine coolant tank from the passegner side fender well. There is a Bolt under the fender, through the tank, but it just spins.
I tried to look in the tank and saw that there is a bolt head actually in the tank but how do I get to it wth out punching a hole in the tank?
Old Oct 26, 2006 | 02:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There are two plastic screws, one above and one below the tank. Both are clearly visible. Place a flat-bladed screw driver under the bolt head and apply a bit of upward pressure. Use a second screw driver to remove.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
