March Press on PS Pump Question
Old Oct 26, 2006 | 07:53 PM
97ramsst's Avatar
Car: 2008 F350 SuperDuty & few F-Bodies
Engine: Twin Turbo 6.4L Power Stroke
Transmission: Yeah, it has one.
Axle/Gears: Yeah, some of those too.
I have a set of March pulleys to put on my car and I was just wondering about the power steering pump pulley. Its a press on pulley...I have to get a PS pump to use and I was just wondering how exactly you press it on? Not to seem stupid, but can you just put the pump in a vise and press it on? Also is there anything that holds the pulley on once its pressed on (I would hate like hell for it to come off and go through my radiator)? I tryed to look up some directions on March's web site and couldnt find a thing...except they recommend a pump for a 77 Camaro.
Old Oct 27, 2006 | 07:51 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
There's a tool used to press it on. or you could get a bolt, nut and washer. put the nut on the bolt then the washer. then thread the bolt in the shaft of the pump with the pulley sitting on the end of the shaft. turn the nut to press the pump on.
Old Oct 27, 2006 | 03:02 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Since the threads are not SAE Course, finding the correct bolt may
take awhile. Check with some of your local parts suppliers -- it
shouldn't be too hard to find one that loans or rents tools like this.
I used one from a local O'Reilly's, & it was very quick & easy (as the
proper tool usually is...)
Good Luck
Old Oct 27, 2006 | 04:10 PM
97ramsst's Avatar
Good Luck
Thanks...I got the tool from OReillys as well.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
