noisy fuel pump by Roy
Old Nov 13, 2006 | 05:35 AM
aretha's Avatar
Hi Guys I am new to the forum.I have a stock 1987 5.7 tpi iroc-z auto. last week my fuel punp has started buzzing when the engine is running also wont shift in to third when pushing her and a lack in power but is ok at low revs there is small pressure in gas tank when the cap is removed the fuel filter is new when i switch the car of the pump still buzzes for afew seconds and stops any ideas would be appreciated.
Old Nov 13, 2006 | 12:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The pressure in the tank when you remove the cap is normal. Running for a few seconds after the ignition is turned off isn't what is intended, but isn't a big deal.
You need to get a pressure gage on the system to monitor fuel pressure while these symptoms occur to determine whether it's a fuel pump problem. It probably is, but you should verify that before changing it out.
Not shifting to third under power is probably a transmission problem (been there, had that). The bad news is you're probably looking at a transmission rebuild.
(Moving this from Carb to Tech.)
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
