EGR Part Number
Old Nov 13, 2006 | 11:48 AM
86z28iroc-z's Avatar
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
EGR Part Number
Ok, I already did a million searches and I couldn't find the information that I was looking for....but
I was wondering what ac-declo part number would be for an egr valve for a 305 camaro tpi? Also, I have no cat, and a free flowing muffler, so would I need to go with a negative back pressure or a positive?? I've gotten mixed results when I was using the search, some say it doesn't matter, some say that it does, but no one has actualy said exactly which one I should use...i don't want to waste 60 bux on something that i can't even use...Thanks!
-Tyler
Old Nov 13, 2006 | 09:05 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
If your engine is not creating any back pressure, a positive back pressure valve will never open. And since your engine is not creating back pressure, it will surely be in a negative pressure mode, which, with a negative back pressure valve, will close under negative conditions, hence will not work.
Old Nov 13, 2006 | 09:19 PM
Car: 86' Z28 Camaro
So...what your saying is that it will not work correctly any way i go?
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
