piston compression distance differences?
Old Nov 20, 2006 | 01:08 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Appearently my block was zero decked to my pistons which had a 1.130 compression distance, my new pistons have a 1.125 compression distance, does this make my new pistons .005 further down the hole or higher up near the cylinder head?
thanks! also, quick question when I am figuring out my CR, it asks for piston to deck clearance, I used to put a zero in it, but now should I make it a .005 or -.005?
Thanks guys !
Old Nov 20, 2006 | 01:14 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
the piston is going to be further down.. and for the compression thing, just do two calculations.. one with -0.005 and one with +0.005 and take the lower compression ratio.. its not that hard to put a minus sign in or take it away.. not tryin to rag on you but next time just try it.. it can only be one of the two..
Old Nov 20, 2006 | 01:19 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thanks I understand, I really needed to know if it would be farther down or farther up, I could have figured out the second part.
Old Nov 20, 2006 | 11:43 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Your new pistons will give you .005 greater clearance.
I like to use this calculator
http://kb-silvolite.com/calc.php?action=comp
It's self explanatory.
Frozer!!!
Jan 19, 2024 04:55 PM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
