MSD timing
Old Nov 23, 2006 | 09:14 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
MSD timing
ok i am trying to set my timing and get it right. I have a snap on timing light. but my msd is realyy messing with the light. it is giving a different reading everyflash. i heard of setting timing with a vaccum gauge but i am trying to setup my motor right and be able to run no2. i want to make sure my timing is perfect. if anyone has any ideas on a timing light that will not jplay havvoc with my msd i would appreciate it or if you know another way to set timing. thanks
Old Nov 23, 2006 | 10:18 AM
Damon's Avatar
My cheap-o Sears Craftsman light has always worked fine with an MSD.
Old Nov 24, 2006 | 09:51 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
i have a snap on and the msd will make the light jump anywere from 4 to 8 degrees.
Old Nov 25, 2006 | 02:31 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
The MSD in my vette makes my dial back timing light jump around, have a cheap none dial back and it works fine with it.
BRoss99
Aug 10, 2025 05:08 PM
toronto formula
Nov 10, 2015 06:17 AM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
