305 valve size?
Old Nov 26, 2006 | 09:42 PM
fg_stadium's Avatar
305 valve size?
what are the valve size on a 83 305 head(416's)
and what would the compression ratio be on a stock bore 350 engine with 305 heads?thanks
Old Nov 26, 2006 | 10:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
1.84/1.5"
around 10:1, do the math to be sure.
Old Nov 26, 2006 | 11:55 PM
Vader's Avatar
And what pistons are in the 350?
'416 heads on a 350 with stock 13-14cc dished pistons would yield about 9.4:1 static CR with a standard deck height and gasket.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
knight72
Aug 10, 2015 09:32 PM
