Roller cam in pre 87
Old Dec 6, 2006 | 06:40 AM
LittlejohnLJ88's Avatar
Car: 92 Camaro RS
Engine: 350 Modified
Axle/Gears: Stock
I have a pre 87 crate moter from summit with a hydraulic flat tappet. I want to change to a roller. I dont want to make some kinda custom thing I want to buy my parts preferably from comp cams. Could anyone tell me exactly what Im gonna need? Ive got a billet timing cover and timing gear already.
Old Dec 6, 2006 | 07:31 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Just the H-Roller cam and retro-fit roller lifters alone will run you $1000 from CompCams.
A complete retro-fit cam kit is about $200 more, but doesn't include the rockers, roller-rockers will add another $400 depending on what you get.
No one can tell exactly what you need because you haven't given any other information other than it's a crate motor. Post more info and you might get some information you can use.
I didn't decide on the cam until I had decided on what heads to use. Then, I filled an online camshaft requisition form at http://www.compcams.com/
Old Dec 6, 2006 | 03:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You could try scrolling down and finding the other active thread on THE EXACT SAME TOPIC.
https://www.thirdgen.org/forums/tech...ters-73-a.html
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
