Code 33 after reubuild/ cam swap.
Old Dec 11, 2006 | 03:10 PM
y5mgisi's Avatar
Car: 90 Chev Suburban 4x4, 5.3L, th400
Engine: 2002 5.3 Vortec swapped in.
Transmission: Stock th400
Axle/Gears: 10blt front/ 14bltSF rear 3.73 gears.
Truck is a 90 chevy suburban with 350 w/th400. Before the rebuild the only code i ever got was the 32. now i have a code 33 which according to this sight http://chevythunder.com/fuel%20injec...0pg%20a.htm#32 Means i have a bad MAP sensor. Just dosnt seam like it would go bad by sitting on the work bench. I'll try to find specs of the cam i put in there but im pretty sure that it is a very computer freindly cam, infact i think i could have even gone up two more steps and still had a happy computer. Anyone have any other tips for me about code 33?
Old Dec 11, 2006 | 03:27 PM
y5mgisi's Avatar
heres cam specs
Basic Operating RPM Range: Idle-5,500 RPM
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 272
Advertised Duration: 262 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.442 in.
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Quantity: Sold individually.
Camshaft, Hydraulic Flat Tappet, Advertised Duration 262/272, Lift .420/.442, Chevy,
gta90
Sep 15, 2015 04:00 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
apie2546
Aug 10, 2015 05:43 PM
