how to adjust roller rockers
Old Dec 15, 2006 | 06:40 PM
smokumZ28's Avatar
Car: 84 CAMARO Z28
Engine: 383 STROKER
Transmission: 350 TURBO
Axle/Gears: 3:73
I have a 383 hydraulic rollers and I sheared a stud on one of my roller rockers and I would like to do the work myself instead of paying a garage. please help. the stud is 2 1/2 in with 1.6 rollers it was my number 8 cyl.
Old Dec 15, 2006 | 11:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The are thread in studs?
ok, so replace the stud, then just put on your rocker until it's at about the same height as the others. Leave that valve cover off, and start up the motor, use oil deflectors if you can grab a set. Then you'll hear it ticking, (or maybe not), back off the nut on #8 until its ticking, then tighten it up until it stops ticking, then add 1/2 a turn. It's called setting valve lash, you can do a search for the other methods, if you want to do it while the motor is off.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
