lt4 balancer hub
Old Dec 17, 2006 | 04:26 PM
ssean92's Avatar
Car: sold
lt4 balancer hub
does anyone know how to get a lt4 (corvette) hub off, is there a diff tool for this one, it is diff then the pressed on one that the camaro uses, this is the one that is notched out and has the key to keep it in place????? the whole in the center is just big enought to get the bolt in so the puller just pusher against the hub so it dont move. i hope this makes since.
Old Dec 18, 2006 | 06:38 AM
ssean92's Avatar
Car: sold
ttt
Old Dec 18, 2006 | 08:52 AM
Vader's Avatar
The LT1/LT4 balancer hub is presses on. Make sure you note the orientation of the hub before removing it. There is an arrowhead cast into the hub for this purpose. Once you remove the balancer from the hub, a standard 3-jaw puller can be used to pull the hub from the crank snout.
Old Dec 28, 2006 | 04:59 PM
ssean92's Avatar
Car: sold
snout.
got it off and the hub will only go on one way, it has a key in it just like the older style. but thanks guys for the info.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
monte87cortez
Sep 26, 2015 08:10 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Magman
Sep 13, 2015 12:14 AM
