rich or lean
Old Dec 20, 2006 | 11:17 PM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
rich or lean
I have a 92 firebird with TBI. I have headers, dual exhaust, dual snorkel air breather, K&N filter.
I plan on get a new ecu chip from tbichips.com. and I have read that some prefer there car to run lean. With the mods I have done do I want it rich or lean.
Why do want your car to run lean compared to rich????
Thanks everyone
Old Dec 21, 2006 | 10:41 PM
redbird92''s Avatar
Car: 92' firebird
come on' Someone knows
Old Dec 22, 2006 | 11:11 AM
1320-camaro-383's Avatar
Car: 91 camaro
Engine: 383 demon 750 rpm heads 150 shot no
Transmission: bto 700r4 stage 3
Axle/Gears: currie 9" 4:10 true track
A properlly running tbi car should constantlly toggle back and forth from rich/lean.Your computer controls that through the info the sensors sends it.The perfect air fuel ratio is 14.1.The chip you plan to buy shoul not change that much or at all.On a carberated car many people like to run rich becauce rich runs cooler and running lean you run hotter.Especially running nos as I do running lean can reck your car I recentlly melted 2 spark plugs down to the threads because my carb was messed up and I ran it lean on the bottle.But as I said your with aplication you dont need to worry about that the computer will do it for you.
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
Jk_Under
Sep 8, 2015 08:13 AM
