Ford FMS/SVO injector info (tech, etc)
Old Dec 21, 2006 | 12:21 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
I'm making this post as I knew I needed injectors awhile back, but there is some spotty info on the Ford injector swap about fitment. I'm hoping to clarify any issues while I've got everything out. Just bought a set of M-9593-A302 24lb injectors from Summit to replace/upgrade the (old/bad) stock 350 injectors in the motor now.
Summit Part # FMS-M-9593-A302 Price 295.95. (injector kit of 8) Yes they've gone WAY up in the last couple of years. (used to be just over $200)
I grabbed a GM fuel rail from a swap meet that was mixed in with a bunch of other parts for the injector "locks", the style that are half moon shaped with one large tab on the end to push or pull for removal/install of the injector. Anyways, point being, I have no idea what this rail/injectors are from. I suspect a 4.3L, as the rearmost injectors are paired while the front single ones are a good distance away. I don't believe the 2.8's or any other motors would be spaced like this. In any case, I only mention in case it is possible these injectors are NOT like the stock Camaro ones. I don't want to mislead, since all my measurements/comparison are based on these.
Overall Length is:
FMS 3.037"
GM 3.135"
Lower O-ring seat lip to injector tip:
FMS .272"
GM .286"
Locking groove to top of injector:
FMS .358"
GM .450"
O-ring diameter:
FMS .563
GM .561
Disclaimer on this measurement: GM o-rings were used, and the test was pretty subjective...very light pressure with the dial caliper jaws, whatever spring pressure the o-ring exerted back was allowed to expand the jaws.
O-ring thickness:
FMS .137"
GM .150"
Even used, GM o-ring is a fair bit thicker...replacing the Ford o-rings with GM is suggested elsewhere on this board.
Upper o-ring seating surface diameter:
FMS .307"
GM .308"
And since a (bad?) picture is worth a 1000 words:
Look to me like everything is well within spec of the GM injectors, and can not cause ANY problems, although I'll be changing out the o-rings, if anyone cares to mic some new GM o-rings and add that info.
Old Dec 21, 2006 | 09:41 AM
camarodarrell's Avatar
The ford injectors fit just fine. I put those same 24's in my 350 tpi with no problems whatsoever.
Old Dec 21, 2006 | 11:16 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Dido.....I have had the pink top on mine for two years now. 22lbs. No complaints. Your set-up shown will work fine. Double check to make sure you don't "bury" the injector all the way down to the intake opening.
Old Dec 21, 2006 | 01:33 PM
Ed Z28 350's Avatar
I put a set of Blue Tops in my IROC many years ago. I did use the GM orings, but I never had any injector related issues (other than improper tuning)
Old Dec 22, 2006 | 04:15 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Axle/Gears: 2.77 9 Bolt
24# on stock TPI?
Can the Ford 24lb fuel injectors be used on a stock long block 350 TPI with TPIS Big Mouth manifold, Accel runners, 52mm throttle body and ported plenum?
Old Dec 22, 2006 | 10:27 AM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
if you used that setup with the stock injectors, you should be fine. stockers are 22# and the ones you want are 24#. you will probably run a bit rich, but probably not. not to big of a difference plus your getting more air in so it should even out somewhat. if you notice you are running to rich, yu might need to invest in a chip to tune your car
Old Feb 28, 2007 | 05:08 PM
PhoenixBoy's Avatar
Which O-Rings are you talking about?
Are the O-rings you speak of the o-rings that go into the fuel rail or the o-Rings that go into the manifold? Which O-rings do I need to replace with the GM ones? Thank you.
Old Feb 28, 2007 | 06:15 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Both of the o-rings should be replaced IMO. I read some older posts regarding the o-rings, at one point the Ford ones were the same or much more similar to the GM ones.
When I replaced the injectors I made the mistake of not measuring the GM "blue" o-rings that I used. They were obviously larger in diameter than the Ford ones, moreso than my above measurements show.
I wouldn't take any chances with pressurized fuel, buy the gm o-ring kit if you swap to ford injectors. The part number for the kit is on this board somewhere, I found it by searching.
Old Mar 31, 2007 | 08:44 AM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Re: Ford FMS/SVO injector info (tech, etc)
Are the ford injectors supposed to ohm in at about 16.5-17 as well?
I've got some out of a f-150 5ltr but have no way of IDing the flow rating. What should I look for when I pick them up?
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
Thornburg
Aug 27, 2015 08:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
