TBI INJECTOR NOT FIRING
Old Dec 21, 2006 | 06:26 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
well got a new toy. 88 2.5 iron duke. motor will run if i feed it gas. but im not getting any out of injector. checked red wire at injector have +12vdc to ground. put test lite across injector and no pulses from ecm. pulled codes and got 34 because i had maf disconnected. pluged it back up and only code 12. checked fuel pump circuit and its working. tps voltage is good. any ideas ? im usually a carb guy and have never played with a 2.5 so any help will be appriciated.
all fuses look good. i searched and read about pulses from dizzy ? any way to check ?
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
