Quick help! slide alt.?
Old Dec 22, 2006 | 03:52 PM
speedy400's Avatar
I have a 92 camaro, with a built 350 (crate). I'm looking to get rid of my ac and smog, can I simply get a belt to go around my crank, alt, and water pump? I know I'd then be loosing the tensioner, and I noticed my alt. isnt on a slide(adjustable), can I get a adjustable mount?? how much hp would I be gaining off this? is it worth it? see the thing is my smog is siezed and my belt needs replacing, i figured I'd just do it all at once.. Possibility? thanks-darren
Old Dec 23, 2006 | 12:20 AM
speedy400's Avatar
bump? one knows?
Old Dec 23, 2006 | 05:55 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
There are ac delete pulleys you can get to keep using the serpentine belt system or you can do like i did and go to the v-belt system. You will need a different alternator brackets and pulleys to do this.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
