Please look need HELP!
Old Dec 23, 2006 | 11:17 PM
Donald1992's Avatar
Car: 1992 Ttop Camaro
Engine: 3.1L v6
ok i bough a 1990 RS camaro 305 TBI Ttop car heres whats going on i got it home and put the key in n nothing tryed to get the car to start turn the key over n nother no cranking no heald lights / interior lights nothing at all the car is power everything i check the ground wire from the batterie to teh fender n its hooked up and i alsed check the block ground at the distributor cap n its hooked up what do i do next i really the car up n running
Old Dec 24, 2006 | 01:59 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey Donald,
I know you may think this is too simple, but from experience I've found that
most times in situation like yours it's usually something simple. Have you
checked your battery connections for corrosion and tightness? Believe me-
it only takes just a little bit of corrosion and a loose connection and you
got nuttin' brudda! While your at it- check the liquid level in the battery,
check ALL connections to and from the battery. Did you try another battery?
Also,check for voltage (with either a voltmeter or a voltage checker - looks
like an ice pick with a wire coming out of it ) at your ignition switch - could
be a bad ignition switch not switching. Hope I could help.
"Hey Moe, no wonder the water don't work -
These pipes is clogged up with wires !"
Jerome Howard - 1939
