quick release steering wheel
Car: 85 camaro z28
Transmission: auto to manaul
will the quick release steering wheel hub from gt grant, work on my grant steering wheel? anyone using one?
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
dont know about down there but in Ma any steering wheel that is not perminantly attached will automaticaly get you arrested for driving to endanger
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Quick release steering wheels are a race only option. Although you could find one to fit your steering wheel, it's not practical to install because most of the upper part of the column needs to be removed to access the quick release. The quick release nut also needs to be welded onto the end of the steering shaft making disassembly of the column for any repairs impossible.
Car: 87 IROC L98
Mr Bean strikes again.
That's a special application not the typical quick release system. What does the cover say?
Car: 85 camaro z28
hey Vader, wat do u think of it?. how hard was it to install and does ur horn and everything else still work?
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
