Rear End Casting Number ?
Old Jan 10, 2007 | 05:27 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Can't find where the casting number would be on a factory 1989 Camaro RS Rear End would be? Its old and I will get out the ole wire brush as soon as I know where to dig. Thanks-
Old Jan 10, 2007 | 06:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the number is on the front side of the pass axel tube. I'd be very surprised if you find anything. If it's a 10-bolt and if you're searching for ratio popping the diff cover and looking might be easier:
Numbers are stamped on the ring and pinion:
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
Old Jan 11, 2007 | 05:14 AM
techno101's Avatar
Car: 1989 Camaro RS
thanks, I'll give that a try.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
