Help me get the right combo.
Old Jan 11, 2007 | 03:03 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Ok i am building a 383 and dont know what i should run for cam/heads and carb. I have a RPM airgap intake i got for cheap form a freind but i am still wondering what to do. I am looking to make in the area of 400-500 Hp at the crank and still run pump gas. What set of heads would be the cheapest but still make the pwoer i am looking for and what cam might i look at using. would i be ok using a 750 carb or 800 or 850. the car will be a street strip car and gas is not the biggest issue for me. can anyone help me out?
thanks
Colt
Old Jan 11, 2007 | 03:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since you already have the intake, you've limited your head selection. You can either eBay the intake and use what works best, or build around the freebe choice. AFR 200 heads should work with that manifold.
Comp XE280-ish cam. Forged flat-top w/valve relief pistons. Good rods with good (ARP) bolts. Good headers like Hooker 2210HKR. 800 CFM double-pumper carb, since you've got a dual-plane intake.
Old Jan 11, 2007 | 08:09 PM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
well if i need to sell the intake i will, that is not a big deal and i am not going to base my set up around my intake, so what i am asking is what could do to make that power with out spending a fortune. like could i mkae that power from a set of ZZ4 heads or will i need something different.
Old Jan 11, 2007 | 11:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
There's a difference between 400 and 500HP. Which do you want? (Keep in mind the higher, the harder it is to drive, more gas guzzled, etc etc.)
400HP-425HP or so, that intake is pretty much the perfect choice.
425HP+ you may want a single plane like a victor junior. It'll hurt your bottom end a tad.
ZZ4 heads have been known to flow pretty poorly. Some members have done quite well with them, but flow results show them as being bad. Take that information with a grain of salt I guess.
I think over 400HP is really pushing it with those heads, i'd say more like Five7's suggestion, or Dart 200cc, brodix or Trickflow 200-210cc size.
Linson
Oct 24, 2025 02:00 PM
Hawk312
Aug 22, 2017 08:55 PM
ydnar417
Sep 23, 2015 05:57 AM
roysatikas
Sep 22, 2015 08:15 PM
Reborn756
Sep 4, 2015 03:42 AM
