coolant gaskets???
Old Jan 17, 2007 | 09:05 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
coolant gaskets???
what gaskets kep coolent from entering the engine itself that would give you white smoke?
on a v8 5.0 305 TPI fuel injected 1986 trans am
Old Jan 19, 2007 | 11:12 AM
Vader's Avatar
Coolant entering the engine will usually produce white smoke/steam from the exhaust. The common places for leakage are head gaskets, intake manifold gaskets, and on a TPI, the coolant passage on the underside of the throttle body can sometimes (if the TB is cracked) introduce coolant to the IAC air passage.
There is also a remote possibility of head or block cracking if the coolant has frozen.
Between performing a thorough visual inspection, a cooling system pressure test, and a cylinder leakage test, you should be able to determine which it is.
Old Jan 19, 2007 | 11:44 AM
Bobby_80s's Avatar
Axle/Gears: no idea
great thanks, im not sure if i do have a leak just hard to tell in the winter time when u can see your breath in the air. so u can definately see the exhaust blowing in the air. but you told me exactly what i needed to know thanks
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
