Those of you with a denso o2
Old Jan 18, 2007 | 08:58 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Is your signal wire a tiny bit thinner than the stock o2's wire. I'm installing a heated 4 wire o2 and just noticed that, and I'm concerned if the added resistance of the smaller wire will effect the signal or not. And if so then I need to exchange it for one with bigger wires.
Or if it's enough to worry about.
Old Jan 19, 2007 | 07:10 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well ohm it out and see
Old Jan 19, 2007 | 07:30 PM
Engine: 3.4
I should've looked closer I guess. I cut the wire on the old o2, the wire itself looks about the same. The insulation is thinner.
UK Speedbird
Aug 28, 2013 06:30 PM
cabech984
Jul 25, 2009 04:40 PM
327_TPI_77_Maro
Dec 5, 2006 12:32 PM
92GTA
Jan 18, 2006 05:28 PM
