Backfire Through Intake when Cold?
Old Jan 27, 2007 | 08:49 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
This is in regards to my '89 IROC (L98 engine)...
Whenever I start my car in the mornings--especially if it's cold--and try to take off, the engine will often bog down down and stumble as if it wanted to die. If I try to give it even more gas while it's doing this (yeah, not going to help, I know), I'll hear a popping through the intake. I then let off of the gas, let the engine pull back up to a normal idle, and then take off by slowly putting on the gas. Subsequent takeoffs are similar in that the engine tries to bog, but not as much. Ultimately, after the engine has run for about 10 minutes, I don't have these problems anymore.
Any ideas what the culprit might be?
Old Jan 27, 2007 | 10:06 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Timing.... Once your car hits operating temp timing is advanced a bit, allowing normal operation.
Backfires through the intake are almost always timing. No other way for flame to get out short of a head leak.
Cornholio7979
Sep 20, 2018 02:31 AM
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 2, 2015 02:01 PM
