Best Spark plugs.
Old Jan 31, 2007 | 06:42 PM
1987camarosport's Avatar
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
Best Spark plugs.
Hey all, i have a 350 outa a early 70's camaro its got a lunuti cam. edlebrock intake and carb. headers 3 inch exhaust, accel HEI ignition. accel wires and i need to change the plugs (just did sea foam) what plugs should i use. are NGK OK or stick with AC delco plugs? I need something to keep up with the engines performance please help.
Joe
Old Jan 31, 2007 | 06:55 PM
Import Killer's Avatar
Car: '92 firebird '90 firebird project
Engine: 3.1 v6 and empty
Axle/Gears: unknown and 4:10 with locker
I would either run the NGK or the bosch plugs. I think that they give a little better spark then ac delco
Old Feb 1, 2007 | 12:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Delcos are black oxide'd, so they're black, and hard to read. I like Champion (I think), because they are silver. Do you know much about the engine? Might want to check what heat range the plugs are that you remove, and see if they were the right heat range first. (in case you weren't thinking of doing that already...)
Old Feb 1, 2007 | 01:43 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i recommend Delcos, the only plug you'll ever find in any of my GMs.
Bubbajones_ya
Oct 25, 2015 08:01 PM
mrbird
Oct 20, 2015 03:43 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
