WHAT EXACTLY DOES TCC SOLENOID DO IN 700R4
Old Feb 28, 2007 | 07:41 PM
bmfIROC-Z's Avatar
YEAH JUST TRYIN TO FIGURE OUT IF I FRIED MY TCC SOLENOID CAUSE WHILE TRYIN TO SET MY MINIMUM AIR RATE ON MY 86 IROC 5.0 TPI I PUT THE PAPER CLIP JUMPER BETWEEN PINS F(TCC SOLENOID)and E(160 serial data output +5vdc)on aldl cause i thought pins A and B were top left but i found otherwise and my tranny is slipping a little when switching gears now and it never did before ,trans is full of fluid and kickdown is set correctly,any ideas? any help would be greatly appreciated!thanx,joe
Old Feb 28, 2007 | 07:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You couldn't have damaged the TCC solenoid by doing that.
Old Feb 28, 2007 | 07:53 PM
bmfIROC-Z's Avatar
would i have damaged anything ?else im just tryin to cover all bases i have alot of $ invested,i appreciate the reply.
Old Feb 28, 2007 | 07:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not likely.
Old Feb 28, 2007 | 08:02 PM
bmfIROC-Z's Avatar
okay ,thanx 4 the quick reply
Old Mar 1, 2007 | 08:12 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Years ago I found out the hard way that paperclips and OBDII don't really care for each other. Blew a lot of stuff on a 99 Z28.
Old Mar 1, 2007 | 03:59 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ditto, but with a brand new 98 Accord before I knew any better. $.45 for a fuse, $245 to replace it at the dealer.
I doubt you damaged anything. The TCC solenoid is fairly robust and the output for the serial is protected. The most likely thing to be damaged in that scenario would be the serial output, as the TCC solenoid would try to make ground through the serial output. Doubtful anything would happen, though.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
