When is duration measured on a cam?
Old Mar 3, 2007 | 05:13 PM
Praetorian27's Avatar
Car: 82 Z28
Engine: 350 bored .030 over w/ 6-71 Weiand
Transmission: Turbo 400
Axle/Gears: Moser 9" w/ 4.56 gears
If I'm not mistaken, you start to measure when the valve is opened .050", and then stop measuring when it reaches .050" closing again. My question is, do you start measuring when the pushrod moves .050"...or when the valve itself opens .050"? If it is the valve...wouldn't the dimensions of the rocker affect the statistic? I have 1.5 to 1 rockers...if it was a longer rocker, it would be a longer duration if measured by the valve movement right?
Thanks!
Old Mar 3, 2007 | 06:08 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i believe it would be more acurate to measure from the pushrod side of the rocker to get cam duration but there is 2 types of measured duration duration at .50 and .005 obvously the duration at .005+ will be longer but i think that any duration over .30 lift should also be calculated in proportion to lift at .50
Old Mar 3, 2007 | 06:20 PM
Car: 91 RS
Engine: 350 vortec
sorry about that i lost sight of what was asked
duration at .50 lift should be measure with a dial indicator on a lifter starting as soon as the dial indicator reads the lobe lift suppled on the cam card then count degrees of rotation while at the specified lift
Old Mar 3, 2007 | 06:43 PM
Car: 82 Z28
Herein lies part of my problem! I have no idea what the cam stats are and have no card. I bought the car as you see it and the seller really had no paperwork to hand over about the engine. I am trying to do some research on part numbers etc. to find out the ingredients!
Old Mar 3, 2007 | 07:26 PM
Car: 91 RS
Engine: 350 vortec
i kinda figured you bought that car. well then the best way to tell would be to pull the topend apart and yank the cam to findout what it is... it is probably a custom grind so i am not sure exactly how P/n 's work with those but i assume you could call the company and ask what the grind is... HOW the hell does someone build a car like that and not save every scrap of paper about the car
Old Mar 3, 2007 | 08:19 PM
Car: 82 Z28
Exactly what I want to know!!
Old Mar 4, 2007 | 01:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You can use a dial indicator with a magnetic base, and a degree wheel. Find the max lift, average it over a few different intake lobes for accuracy, and a few exhausts.
Yes, you measure on the pushrod side. And you're right, using a 1.6 rocker changes your duration slightly.
Comp cams measures ADVERTISED duration @.006", crane at .004". So measure it at .050" lift, and the max lift, and the .006 duration, and .004 duration. That should give you enough info to find out what it is - before pulling it out.
Sexy car BTW!
Jorlain
Oct 8, 2015 01:57 AM
rb85TA
26
Sep 14, 2015 10:29 PM
BAMiller
Sep 14, 2015 06:38 PM
apie2546
Sep 5, 2015 07:40 PM
