questions on shaved heads
Old Mar 3, 2007 | 05:47 PM
dragonslayerrb3's Avatar
Car: 91 RS
Engine: 305 tbi
Transmission: T-5 5 speed
Axle/Gears: Stock
i blew a head gasket on my 91 camaro 305 tbi.i took the heads to the machine shop for vavle job and resurfacing.he took them down .020.will this affect anything with the way the computer runs the engine?and will it boost the compression enough to tell it? I've never had much dealings with newer computer controled engines so any help would be appreciated.
thanks in advance
Old Mar 3, 2007 | 07:00 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
If you have stock pistons then no. It is not even enough to worry about higher octane fuel.
Old Mar 4, 2007 | 01:59 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Chances are you're going from a stock .015" thick head gasket to an aftermarket .039" thick one, so that .020" milled off will make it pretty much identical to the way it was before.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
theurge
Aug 21, 2015 12:46 PM
madsv1000
Aug 20, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
