what springs to use in AFR heads
Old Mar 4, 2007 | 01:07 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
i got myself a set of new afr 195 eliminators (for only 1200 canadian i might add ) . I"m expecting to have to upgrade the springs for the size of cam i want to use. I want something just under 600 lift. the motor is going to be a fuel injected (hsr set up) with a 406. I was looking at comp cams fuel injected ones, the XFI. and would probably use there biggest one. i believe it was a .590 lift of some kind. just wondering if anyone recomends a spring specific for a hydraulic roller of that size.
cheers
blake
Old Mar 4, 2007 | 01:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think the comp 987's are what you'd be looking at. See what spring is recommended by comp for the cam, I think the 987 would be it.
Nice deal on the heads, where'd you get them?
Old Mar 4, 2007 | 06:08 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
For springs, this is what is on AFR's website
1.290" OD Hydraulic dual valve spring w/ dampener, 130lbs on seat AFR #8017 .600" maximum lift (upgrades available) Comp Pkg #8019
As for the cam, I have the same heads, so I am going with the 280xfi with my 383. I think the lift is 0.576 int./0.570 exh. lift.
For your heads, were they assembled? If so, they have the springs that are mentioned above.
Old Mar 4, 2007 | 07:49 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
yes they are fully assembled. so it sounds like they are ready for a cam which of that size?
i bought the heads off a guy who bought them a week prior for 2200 canadian. needed the money. its good being patient i guess. i've been waiting for about a year for a deal
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
gixxer92
Sep 1, 2015 04:32 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
