gaskets etc for AFR heads
Old Mar 11, 2007 | 12:42 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
just wondering if you have to use the specific gaskets AFR tries to sell you for there heads. i have a 406 i'm putting these 195's onto. what gaskets would i use, if other than out of the felpro rebuild gasket set, would i use?
also what about head studs, bolts. same lenght as usual?
and same length of push rods etc?
cheers
blake
Old Mar 11, 2007 | 06:39 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Use the gaskets they recommened. The biggest thing with your heads, Make sure you have them drilled for the steam holes. Use felpro gaskets.
Head bolts are the same- Rememver to use teflon sealer for them!
Pushrods shouldnt change, Pick up a pushrod length checker, there cheap and easy to use.
Old Mar 12, 2007 | 12:39 AM
EvilCartman's Avatar
Car: '82 Z28
Far as intake gaskets, I've always used the Felpro 1205. Pushrods, I had to get longer ones so make sure you check things over.
evilstuie
Jan 9, 2020 08:29 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
