im so confusied
Car: 1988 camaro
Engine: 2.8 tpi soon 383
Transmission: 5 speed manual
im so confusied
allright so i bought another project f-body and its really confusing me....thursday i pulled the starter because i was unable to get the engine to turn over took it down had it tested failed so purchesed a new one and installed it today go and hop into the drivers seat turn the key nothing no dinging, no cranking no nothing so i think batt i hook up cables to my truck try and get any type of charge outta it nothing. the batt is brand freakin new and the only thing ive done is the starter any ideas on what my problem is guys?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: im so confusied
is the solenoid wire getting power when the ignition key switch is in crank position
if not then try a new ignition switch
or make sure the shifter is all the way in park or neutral
check the wiring on the shifter assembly, make sure the plug is not loose
also under the dash is a larger purple and a larger yellow wire, jump them together with a paper clip
but only if the solenoid wire is not getting power in crank position
Car: 1988 camaro
Re: im so confusied
thanks man ill give it a look over in the morning....damn i never had this much trouble with my 81 T/A.
