Billet specialties brackets?
Car: 89 Iroc-z
Engine: 396 Stroker 625hp
Transmission: 700r4 3000 stall
I am wanting to get the midmount billet specialties alternator bracket for my 383. But from the picture it shows, it looks like an extra bolt hole is needed on the water pump. Because my water pump only has two bolt holes on each side that mounts the water pump to the block. Is that all that needed for this bracket to work? Will I need a new waterpump with that extra bolt hole if it is necessary? This is the bracket its the small block chevy mid mount. Also, I looked at my water pump and there is a place where it looks like a whole could be drilled and tapped for the turnbuckle on the new bracket. http://www.jegs.com/webapp/wcs/store...0002_761472_-1
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Billet specialties brackets?
I'm also interested. I have the ps bracket from them that i'm trying to fab up to mount. What sucks is i'm going to have to cut up or at least elongate some holes in my new brackets.
Car: 89 Iroc-z
Nevermind guys, I plan on going with an electric water pump now and will need a whole different system for my brackets, whats a good setup that looks nice for alternator and powersteering brackets?
school boy
Oct 22, 2015 11:47 AM
