question??
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: question??
Should be on the drivers side head, between the #1 and #3 spark plugs. It's either a green or a purple wire, my memory is hazy. I want to say green.
That's what works your coolant gauge, if you mean for the fan relay, that's on the passenger side head.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: question??
if you mean the CTS for the ECM, its on the intake near the thermostat, it has a 2 wire connector going to it.
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
Re: question??
well my car is running hot (240)all the time I have the air dam on,,new thermostat,,new water pump,,manual fans so they stay on all the time so now I am going to change the temp sens. now that I know where it is
thanks guys
steve
thanks guys
steve
