Where are the different sensors located?
Old Mar 29, 2007 | 09:55 PM
Speedball's Avatar
Car: 1989 Camaro Iroc-Z
Hi guys.
I am in the need for some detailed information from you guys. I wonder where the different oilpreassure sensors, knock sensors and other vital sensors are located on my 350 TPI engine. I have purchased Haynes Repair Manual, but I didnt see any pictures or description of ALL the sensors. I have some sensors that are without wireing and some sensors with bad connection so I would like to get these replaced with the right type of connectors.
The engine is running uneven when it warms up, but gives no codes. So I was thinking of changing all the ignition parts like rotor and cables and plugs as well as getting better connectors to the sensors. If anybody has any tips of what more I should do, please give me feedback!
Thanks guys!
Old Mar 29, 2007 | 10:35 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Where are the different sensors located?
hi there well first give it an ignition tune up and make sure the injectors are spraying correctly
new wires, plugs, rotor, cap, and such would be a good start
do those first
go from there
i have emissions diagrams in a book here
if you need, but first do the tune up
good luck
Old Mar 31, 2007 | 10:04 PM
svroom's Avatar
See atttached diagram for locations of sensors
Old Apr 7, 2007 | 11:40 AM
Speedball's Avatar
Thanks guys. you are the best.
Is can I buy any type of plugs and wires or is there a certain brand that is to be recommended?
Nick McCardle
Sep 10, 2015 08:36 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
willyjoejr
Sep 3, 2015 09:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
