Question about a 350 build?
Old Apr 3, 2007 | 12:01 PM
pookey_03's Avatar
Will this block bolt up in my 86 iroc?
http://www.jegs.com/webapp/wcs/store...1058_-1_395210
Old Apr 3, 2007 | 12:07 PM
Re: Question about a 350 build?
Mostly, yes.
It has a driver's side oil dipstick, which is not compatible with your exhaust manifolds. Headers fix that.
It has the 2-pc rear main seal, which means your flex plate or flywheel won't fit it. You'll need the one from a 83-85 Camaro/Firebird V8.
Other than those 2 things, it's a drop-in.
Old Apr 3, 2007 | 01:58 PM
pookey_03's Avatar
I plan on putting on some decent heads and my tpi, will i be able to run a roller cam also?
Old Apr 3, 2007 | 02:03 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
that motor would be flat tappet because of the 2-pc rear main seal. but look on jegs or summit for a retro fit kit to convert it to a roller cam if you would like.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
