Guess My Horsepower?
Old Apr 12, 2007 | 07:37 AM
MR NICE's Avatar
Hi to All,I would like to get a guesstimate on the appox. crank HP/TQ on my build, here is what I'm putting together.Thanks for any help.
350ci Flat top forged pistons
Bow tie Phase 3 heads 202/160 64cc chamber 184cc intake runner
Comp Cam XFI Camshaft Flat Tappet Hyd, Gross Lift 520in/515ex Dur 224* 231*@.50 w/1.6 rocker 113 lobe sep
Comp Mag roller rockers ratio1.6 comp lifters& pushrods
Lt1 intake conversion
Custom chip
Short Headers true duals no cats
Gut MAF
How do you guys think this combo will run?it is going in a 85 vette with 3.07 rear gear auto trans.Any guesses on idle quality,HP? Thanks again.
Old May 10, 2007 | 07:30 PM
MR NICE's Avatar
Re: Guess My Horsepower?
Old May 10, 2007 | 07:53 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Its going in a 'Vette? BAH!!
Just kidding..
If I were to take a stab at it, you should be running
between 295-300HP at the wheels..maybe.
Its hard to define a build, we have no idea who
tuned it..but, going by instinct its looks solid.
Why flat tappet? I like them, use 'em all the
time. But, for your setup I would have done at
least Hydraulic roller. 'Cause it looks it could be
a high winder.
LSA on the cam is acceptable, 112-114 on
computer controlled stuff is the limit, so your
borderline..
Id say, 303HP/330ft. lbs TQ at the wheels
Best case scenario, of course ..
Old May 10, 2007 | 08:21 PM
MR NICE's Avatar
Thanks, i went with a flat tappet cam because my block is non roller and my small buget.
Old May 12, 2007 | 11:30 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
If I had to guess, 2. A guess is just what it is, a guess. If you've got the $ to build it, spend some more on a dyno and find out for sure! A dyno print out will be a selling point when you decide to sell it not to mention the bragging rights to your buddies!
Old May 13, 2007 | 06:09 AM
MR NICE's Avatar
That is a good idea when it's finished,but I was looking for a appox. HP figure for now,make sence?
Old May 13, 2007 | 07:13 AM
TPI's Avatar
Yea, its completely understandable to get
a rough estimation of the build's power potential.
I think idle/streetable wise, it'll be stunning.
Ive no prior experiences with a LT1 induction,
but it should make good numbers past 5000rpm.
Flat tappets are a cheap and effective way
to make power and getting your car on the road.
But, If you have roller provisions on the block,
Id suggest going with a nice Comp or Crane
hydraulic roller grind, I just saw you dont.
Stray away from synthetic blend oils &
be generous with the assembly lube if It
hasn't been built yet, Flat tappets like the
conventional stuff.
Good luck
Old May 13, 2007 | 08:47 AM
MR NICE's Avatar
Thanks,i'm running shell desiel oil with EOS,I'm almost finished can't wait to fire it up,another couple weeks.
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
