help diagnose video of problem
Old Apr 14, 2007 | 12:30 PM
texanwitharake's Avatar
Car: 1988 camaro
Engine: 2.8 tpi soon 383
Transmission: 5 speed manual
ok having a problem starting my camaro 2.8 v6
ive replaced
Fuel pump
spark plugs
spark pluge wireset
coil
distributor cap & rotor
battery
the way it gose it basicly key into ignition turn to accessorys i can hear the fuel pump prime and when i turn the key i hear this (sorry about the angle i was trying to film and start it) http://www.youtube.com/watch?v=K2ILJ7d4R_Y (the break in cranking was me letting the batt recharge and the fuel pump to re prime) any ideas on whats keeping my car from starting?
Old Apr 14, 2007 | 12:43 PM
speedracer0626's Avatar
Car: 89 Bird 93 Old Cutlass Ciera
Engine: 305/ 3.8 S.C.
Transmission: 700r4 and IDK
Axle/Gears: ????????
Re: help diagnose video of problem
Have you changed the fuel filter because that is the first thing I would do. process of elimination is what this calls for. also check the regulator as that could be a problem
Sounds like a fuel starvation problem.
Last edited by speedracer0626; Apr 14, 2007 at 03:23 PM. Reason: Automerged Doublepost
Old Apr 14, 2007 | 03:07 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What have you checked so far? Does it have spark? Is it getting fuel? What's the fuel pressure? What you tried starting fluid? It sounds like it wants to run but isnt getting fuel..
Old Apr 14, 2007 | 06:25 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Check your pickup coil inside the distributor - wires get covered in funk and break: a common problem. Also, another common problem is a bad ignition module - pretty inexpensive. Do some more troubleshooting first before throwing parts at it. Do you have spark? 12v at coil? all fuses good? Fuel pressure at spec?
Good Luck,
Corky
Old Apr 15, 2007 | 07:02 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If it's a TBI looking into the throttle body while cranking if it isn't spraying any fuel it might be bad injectors, or no signal pulse getting to them.
Old Apr 15, 2007 | 10:12 AM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
I had a similar problem on my car 5.0 tpi and the problem was the fuel pump oil pressure switch it was messed and wasn't sensing oil pressure so it would prime the pump but when i turned it over there was ne power going to my fuel pump , not sure if ur 2.8 has 1 but that is a good place to check , it should be mounted above the oil filter hope this helps.
Old Apr 15, 2007 | 10:35 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
I've unplugged the fuel pump oil pressure switch, and it didn't keep my car from priming, or starting up and idling. If I remove the fuel pump relay the pump won't prime but, will start pumping after a longer crank time and the engine does startup and idle.
Old Apr 16, 2007 | 12:23 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
The oil pressure switch will only keep the car from running if the fuel pump relay is also bad.
Old May 8, 2007 | 08:18 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
have you happened to solve this problem yet?? im goin through the same crap with my car right now
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
theshackle
Mar 5, 2017 06:37 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
