How do you use this ?
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Searched on the forum and couldn't find any info
http://www.partsamerica.com/ProductD...pe=818&PTSet=A
I didn't even know what it was until I by accident came across it while looking for parts, and the part is included in my Fel-Pro gasket kit. I figure you pry out the old one and put the new one in, somehow ? But what's the little tube ? Sealant ? The same one we use on head bolts and intake bolts ?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: How do you use this ?
Your link didnt work. Im guessing it is probably gasket maker or a sealant like you said.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Thats a repair sleeve for your harmonic balancer, you simply install it over the snout of the balancer if its worn or grooved.
Transmission: 4L80E/4L80E
Harmonic Balancer Repair Sleeve.
There isn't an old one on the damper (what they call "balancer"). It's to repair the groove often left in the damper by the front seal.
The little tube is a Locktite type compound. It locks the sleeve onto the damper. You put a few drops of the stuff inside the sleeve, and carefully drive the sleeve onto the nose of the damper. The front seal will then have a nice smooth and slightly larger OD surface to run on.
If your damper isn't grooved, you don't need to bother with it.
