Rockers
Old Apr 18, 2007 | 11:28 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Rockers
Did they change anything on the rockers from the oldschool GenI SBC to the roller blocks?
Old Apr 18, 2007 | 11:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Rockers
Self aligning, not sure when exactly that change took place. Slots for pushrods mean you can use non SA rockers, if no slots (big holes) then either SA rockers or guide plates.
Is that what you are asking?
Old Apr 18, 2007 | 11:44 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Re: Rockers
Pretty much, just wondering about the interchangability of the 2...
Say you wanted to run the newer SA rockers on an old head or non SA rockers on a new head...
Old Apr 18, 2007 | 11:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Rockers
oh, I know sofakingdom wrote up a little info on it before, let me see if I can regurgitate it here:
You need one (and only one) method of aligning your rockers.
-Slotted pushrod holes (stock before 199x)
-Self aligning rockers and big round pushrod holes (stock after 199x)
-Big round pushrod holes and non SA rockers, but guideplates (only aftermarket)
You can't really use more than one method, else you run the risk of them binding.
You can grab a 1/2 drill bit and gouge out your slotted pushrod holes and use SA rockers, or guide plates.
You can run non SA rockers on a newer head that has the big holes, if you cut down your rocker stud boss and use guide plates.
So yea, you can pick and choose your method. As far as what's the best method? I think guideplates are most common in aftermarket, maybe that means they're superior? I'd be inclined to think it's the SA rockers though.
Old Apr 19, 2007 | 05:07 AM
Pat Hall's Avatar
Re: Rockers
Keep in mind that you'll need to buy hardened pushrods if you decide to use guideplates.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
ericjon262
Sep 11, 2015 06:07 PM
