serpentine belt problem
Old Apr 19, 2007 | 08:42 PM
built's Avatar
Car: 82 TA
I have a friend who has a 90's camaro and his ac compressor is locled up and the belt is burning and he can't drive the car.
Is there anyway to bypass the ac so he can drive it till he can repair or replace the compressor.
What can he do to make it drivable.
Old Apr 19, 2007 | 09:31 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: serpentine belt problem
Sounds like his clutch must have locked up and the compressor is shot too. Be about as cheap as anything to put on a junkyard or rebuilt compressor. Don't have to recharge the system just for driving. The clutch will spin free so the belt won't burn.
Old Apr 19, 2007 | 09:48 PM
built's Avatar
Car: 82 TA
yep thats what i think happend, the pulley bearing was getting real loose and now it's stuck.
Old Apr 20, 2007 | 11:35 AM
Guest
Guest
Posts: n/a
Based on this picture
I think you may be able to route the belt over the tensioner instead of under, and skip the AC compressor and run right to the smog pump to get around it temporarily but that would require a new belt and it may not clear the AC pulley. Might be easier to do the junkyard AC thing.
Old Apr 20, 2007 | 09:03 PM
built's Avatar
Car: 82 TA
I never have good enough luck,I'm trying to help him and he has worse luck than me it seems.
I don't know if over the tensioner will work, the pulley seems like it's in the way, i'll have to look at it again.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
