1990 Trans Am GTA: question about mass air flow sensor
Old Apr 27, 2007 | 12:25 AM
adreed24's Avatar
Car: 1990 Trans Am GTA
Engine: 5.7 liter, 350 V8
Transmission: 4 speed auto.
I have a 1990 Pontiac Trans Am GTA, with the 350 cu. in. (5.7 liter) Tuned Port Injected V8 engine. The car has some problems with idling too fast, or too slow, and sometimes, the engine cuts out. I was told that one of the things to check is the "mass air flow sensor".
I would like to know if this car has a "mass air flow sensor", and if so, where is it located?
Thanks in advance!
Old Apr 27, 2007 | 12:31 AM
F-Body Demon's Avatar
Re: 1990 Trans Am GTA: question about mass air flow sensor
Actually you dont have a MAF. your system is Speed Density, it uses the TPS sensor and the MAP sensor. I have a 91, and I looked for the maf for like 20 minutes one day and got fed up and looked it up (how I found TGO) lmao.
Check and clean your TPS sensor IMO.
Old Apr 27, 2007 | 05:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Nope. No "mass air flow sensor" on your car.
The TPS doesn't get dirty. You probably mean check the TPS and check and clean the IAC.
Old Apr 27, 2007 | 11:29 PM
adreed24's Avatar
Could someone tell me where the "MAP sensor" is located?
I replaced the TPS. I don't think it requires any adjusting, does it?
I had the IAC valve replaced by a mechanic. He told me that it would take a few days of driving for the computer to "learn" that a new IAC valve had been installed.
Unfortunately, I don't think this happened. The car is still not idling right months later. I suspect that it might be the computer (ECM), but I was told that if there are NO codes showing (relating to the ECM itself), that means there is nothing wrong with the computer.
Of course, I have been told the opposite as well; that the computer can be faulty and NOT show a code.
When the engine runs, it runs very well, except for this idling problem.
I am not sure what is wrong. Any ideas?
Old Apr 28, 2007 | 05:51 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
https://www.thirdgen.org/tpimod2
IAC and TPS adjustment procedure from thirdgen's tech articles. Give it a shot and see what happens.
Old Apr 28, 2007 | 06:15 AM
+1 What he said
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
