buying new fuel injectors help!
Old May 2, 2007 | 12:07 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i'm buying new fuel injectors.
i believe my stock is 19lb???
am i right? i have a 1986 trans am 5.0 v8 fuel injected tpi 305
i want to get stock ib's because i dont have time or money to get a new fuel pump and ECM chip to compensate for teh extra beefed up injectors.
btu any suggestions before i go forward would be great.
Old May 2, 2007 | 12:22 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: buying new fuel injectors help!
depends on what ur doing, ur stock 305 has 19lb injectors and if u boost the fuel pressure they can support 300hp with ur 305 mabye 350hp. it depends on what ur doing to ur engine and wat fuel pressure ur gona run. if ur injectors arent bad and if ur not doing alot to the motor like cam, heads, intake etc i would just get an adj fuel pressure reg and set it at 50psi, that will give u more fuel that u would need for what ever ur doing. and only cost u 60-90$. if u decide to get new injectors for ur stock motor dont go higher than 19lbs, 22's like the 350 would be too much. and dont get cheapies, buy bosch or good name brands u dont wanna skimp on quality with injectors.
Old May 2, 2007 | 01:16 PM
Bobby_80s's Avatar
Axle/Gears: no idea
well i am going to install a adjustable fuel pressure regulator.
but these r the original injectors and if i'm taking the runners and plenum off to clean and polish i might as well do some work on teh fuel rail and injectors.
i just want to know if i should go to the dealership or is there an aftermarket brand taht will be more reliable and more worth the money for stock/long life/reliability/ and reasonable price.
Old May 2, 2007 | 01:21 PM
Bobby_80s's Avatar
Axle/Gears: no idea
already have brand new throttle body and k&n cold air kit. cleaning up the engine and tryign to figure out what is causing me to have a rough cold start.
car runs and idles fine once warmed up. ive already purchased the coolent temp sensor and cold start switch.
already going to install the afpr and while im at it i just wanna cover all my basis now instead of keep taking the plenum and other parts of teh engine apart everytime i try to narrow down the problem.
already been through the tuning and adjustments and new IAC. set my tps.
new cap/rotor/ignition modual/wires/plugs
oil flush/filter
car is a project and wasnt treated great by previous owners. so might as well do some overhaul on the basics and see what i get.
like i said car drives fine but needs a boost in power and reliability. already passed emmisions.
so just curious which injectors i should buy that are reasonably cheap and from who
i just want a nice joy ride/cruiser, nothing to race but just to have some fun with and can handle a heavy foot every now n then
Old May 2, 2007 | 05:13 PM
Car: 87 TA clone
well if ur gona replace them accels are good, Bosch are great, ur injectors are prob fine if ur passing emissions u could just send them out to be flow tested and cleaned maybe even rebuilt, why pay the extra money if u dont need to. if ur car runs fine when its warm its not ur injectors its ur cold start injector which has been discontinued....so ur not gona find any replacements out there, the 50psi fuel pressure increase will help ur cold starts as it did with mine. if ur sensors are good and have been replaced and it only happens when the engine is cold my guess is the cold start injector, u should also replace the O2 sensor bc ur car will run like crap cold if that is bad or going.
Old May 2, 2007 | 05:21 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok i was wonderign why i couldnt find that 9th cold injector.
thats so stupid things get dscontinued. if anything build them per order.
anyways new bosch o2 sensor but its reading lean. code 44.
im goign through the motions to find why. if its bad or if its my maf or my injectors or my fuel pressure etc..
anyone know how to test the air divert valve solenoids?
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
