Timing Tab
Old May 3, 2007 | 08:39 PM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Timing Tab
I have a 90 RS that has a 350 TPI from a 90 Z28. Would the timing tab have been at the 12:00 or 2:30 position? I feel stupid, but when I converted from TPI over to Carburetion, I lost the timing tab and forgot what position it came from. I'm one of the many lost souls with one of those O'Smiley special chrome timing tabs, and now can't read my timing correctly. This particular one is mounted at the 2:30 position. Is it the correct one or do I need to find one that mounts at 12?
Old May 3, 2007 | 10:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Best thing to do is to pull the front pulley & damper bolt/washer off and look at the keyway relative to the TDC timing mark. If they're pretty close to lined up, you need the 2 o'clock tab. If the TDC mark is to the left (counter clockwise) of the keyway, you need the 12 o'clock tab.
Old May 3, 2007 | 10:26 PM
Engine: 355 TPI
Re: Timing Tab
Alright, I will do that.
Does anyone even sell a tab that goes in the 12:00 position? Or would I hafta go junkyard hunting?
Old May 3, 2007 | 10:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Timing Tab
Tabs in the 12:00 position are welded to the cover. There's no reason why you couldn't remark your balancer to work with any tab you wanted, though.
midge54
Dec 27, 2019 04:14 PM
The_Phoenix
Feb 4, 2016 07:10 AM
masonta
Aug 31, 2015 10:14 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
