1.5 rr under perm covers??
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i just got a set of 1.5 roller rockers and i was wondering if they would fit under stock perimitor bolt valve covers??
Transmission: 4L80E/4L80E
You'll probably have to trim the baffles to get clearance, depending upon the particular rockers you got.
The Pro Comp stainless steel roller rockers from Comp Cams are about the only ones that clear without problems.
Re: 1.5 rr under perm covers??
They'll clear under just about any aftermarket covers though. I'm running the standard height Edelbrock Elite Series perimeter bolt covers with the bulky Harland Sharp, aluminum, 1.5 rr's w/poly locks, and they clear just fine. Most cast aluminum covers just use a small tin plate with two rivets or screws as a baffle, so they don't interfere at all. It's the stamped steel ones with the large baffle assembly that have clearance issues. Thread
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
