Super easy Q. Will 89 Vortec 305 Heads help my Crate 1st Gen SBC 350?
Old May 17, 2007 | 07:11 PM
rx7 punk's Avatar
Car: 88 Mazda RX7
Engine: 305- Headers, -680cfm Quadrajet,-flex-a-lite dual fans
Transmission: t5
I picked up a Crate SBC for $900 still in the packing from a old guy yesterday and was wondering if there was any advantage to using the Vortec 305 heads would boost my power at all.
The SBC is advertised at 290hp and 326tq.
PS, the SBC is going in a 88 Mazda Rx7
Thanks guys!
Old May 17, 2007 | 08:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Most likely they'll help through increased compression and flow.
Old May 17, 2007 | 10:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Super easy Q. Will 89 Vortec 305 Heads help my Crate 1st Gen SBC 350?
in 1989 there were no vortec heads
Old May 19, 2007 | 01:59 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Oh yea... haha, I think he typo'd in his subject line, I think it's an '89 block, and he wants to put on 305 Vortec heads... (....RIGHT?)
Do you know what heads are on that crate engine? I'd guess 993 heads, but... make sure first..
Old May 19, 2007 | 08:26 PM
Damon's Avatar
The 305 (5.0L) version of the Vortec heads is not the equal of their larger brother- the 350/5.7L Vortec heads. The 350 Vortec heads are the ones that you hear so much about in the magazines and on the internet.
The 290HP GMPP crate motor uses 993 castings with 1.94/1.50 valves and 76cc chambers. They're pretty crappy by today's standards and they only provide 8.5:1 compression on that motor (which uses -12cc dished pistons).
If 305 Vortec are what you got, then maybe give them a shot. They have mush smaller ~58cc chambers and smaller valves than your current heads (1.84/1.50, I beleive) but they probably flow about the same and the much smaller chambers will get you up to a more reasonable compression ratio in the mid-upper 9s. I bet they will make a little more power and lot more torque than the stock 993s, but that's just a guess.
FormulasOnly
Jul 23, 2018 08:47 AM
no green
Jan 9, 2016 09:22 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
