Help!!!
Car: 87 Camaro Bertalina
Engine: 2.8 V6 MPFI
Transmission: TH400
Axle/Gears: Stock
Help!!!
Car will crank up after 5 or six cranks and run fine when warm. It goes to 1500 RPMs and then goes back down. Once I do this the car will crank everytime if it is warm of at least 65 degrees or more. But anything under that it will not crank no matter what. I had a tune up and replaced the dis cap rotor and button. smelt oil when i cranked it last for a few mins then it went away. what could be the problem and poss solutions. Need to know as hence the car is my daily driver
